Link para Electrónicos
Muchas gracias Raul, los probaré.
Eres un hombre de recursos te pareces a MacGyver  ;)
Página con diagramas de muchos conectores y cables:
http://web.archive.org/web/20030620170622/www.hardwarebook.net/
Y aunque no es mi preferido, la versión gratuita tiene todas las funciones y te permite hasta 250 pines:
http://www.vutrax.co.uk/vtxcd.htm
http://www.vutrax.co.uk/vtxcd13_2a_08mar2008.iso
Todo esto, y además gratis:
    [Electronics - DC Current flow - Basic Electronics - Resistor Value Test - Simple DC Circuits - Types of Switching - Variable Voltages - Ohm's Law - DC Voltage - DC Current - Series/Parallel Resistors - AC Measurements - AC Voltage and Current - AC Theory - RCL Series Circuits - RCL Parallel Circuits - Capacitance - Capacitors - Inductance - Inductors - Impedance - Radio and Communication - Attenuators - Passive Filters - Active Filters - Oscillators - Circuit Theorems - Complex Numbers - Electrical - DC Power - AC Power - Silicon Controlled Rectifier - Power Supplies - Voltage Regulation - Magnetism - Transformers - Three Phase Systems - Energy Transfer and Cost - SemiConductors - Atomic Structures - Diode Theory - Diode Applications - Transistor Theory - Bipolar Transistor - Transistor Configurations - Active Transistor Circuits - Field Effect Transistors - Basic Operational Amplifier - Op-Amp Theory - Op-Amp Applications - Sum and Difference Amp - Testing - Analogue Multi-meter - Measurement -Mathematics - Number Systems - Number Conversion - Number Types - Roots - Angles and Parallels - Triangle Ratios - Triangle Angles - Percentages - Ratios - Fractions - Vectors - Circle Angles - Algebra Rules - Algebra - Mathematical Rules - Powers and Indices - Simplifying - Equations - Graphing - Slope and Translation - Curves and Angle Conversion - Personal Finance - Mechanics - Area - Surface Area and Symmetry - Volume - Compound Measures - Geometry - Motion - Optics -Computing and Logic - Hardware Devices - Data Structures - Data Files - Computer Systems - Data Handling - System Development - Computer Programming - Data Analysis - Binary Numbers - Binary Arithmetic - Digital Techniques - Logic Gates 1 - Logic Gates 2 - Logic Families - Flip Flops - Combinational Logic - Counters - Counting - Shift Registers - Logic Interfacing - 555 Timer - Boolean and DeMorgan's - Microprocessors - Micro-Computer - Data/Address Bus - A.L.U - Clock and Reset - Instructions and Control Requirements: Windows 9x What's New: Now a FREE Download package for Students, Hobbyists and Electronics Engineers.]
http://www.brothersoft.com/electronics-mech-maths-and-computing-download-58597.html
http://www.brothersoft.com/d.php?soft_id=58597&url=http%3A%2F%2Fwww.eptsoft.com%2FElectronicsMech%2FElectronics%2520setup.exe
http://www.eptsoft.com/fence/content/cheetah.php?m=fs&ident=
No tengo claro si está mejor aquí o en DIY, pero quien quiera hacerse un buen ampli puede probar con este:
http://www.lf-pro.net/mbittner/Sym5_Webpage/symasym5_3.html
http://www.holgerbarske.com/art/artikel.php?id=24
...y otro:
http://www.holgerbarske.com/art/artikel.php?id=9
... y habrá que parar una temporada:
http://www.epanorama.net/links/audiocircuits.html#links
Yo de momento tengo ganas de probar como van las placas chinas de eBay pues si funcionan medianamente bien uno se puede hacer un ampli por poco dinero.
Hola Rodrigo,
¿Has probado esto? Es increíble la cantidad de recursos gratis que hay en el mundo sajón:
http://www.auriculares.org/foro/index.php/topic,1929.msg34646.html#msg34646
ErNovato
#112
Cita de: Raul_77 en Diciembre 25, 2009, 14:32:48
Hola otra vez,
Ese material nunca se acaba, lo que se acaba es el anuncio, al mismo tiempo que te dice que ha finalizado también te dice que se ha vuelto a poner en venta, normalmente ya te ponen el link para el nuevo anuncio. Sino, con hacer una búsqueda de ese artículo en el mismo vendedor lo encuentras.
Aquí tienes los actuales:
http://shop.ebay.es/virtualvillage-ie-delta/m.html?_nkw=Solder+Iron+Replacement&_sacat=0&_trksid=p3911.m270.l1313&_odkw=&_osacat=0
http://cgi.ebay.es/Estacion-de-soldadura-de-hierro-60Watt-mano-Herramienta_W0QQitemZ270505612889QQcmdZViewItemQQptZLH_DefaultDomain_186?hash=item3efb641659
http://cgi.ebay.es/Replacement-Soldering-Iron-For-ESD936-Soldering-Station_W0QQitemZ380190842970QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item588523e05a
Gracias, Raul.  En Madrid no encuentro la 936..Me dicen que hasta mediados de enero no llega de nuevo el barquito de la China...Me esperaré , me sale prácticamente lo mismo que comprar la 938 a un almacen de Tarragona...
Por ebay parece barato, Raúl, pero se encarece por los gastos de envío.. Hay que tener cuidado, porque, por ejemplo, la 936 dice que el artículo se localiza en Madrid, pero abajo del todo aparece la dirección real..en Hong Kong! Al final la factura te sale por 33,84 jeurakos.  :D
Las puntas de reemplazo están en China, los gastos de envío son 5 euros, pero en la factura final no se reflejan (5,90 euros), pienso que te lo encasquetan aparte. En cuanto al soldador de reemplazo (¿China?), los gastos de envío son gratuitos (eso dicen).  Si consigo contrastar esto último, me lo pillo..
Sobre la malla, puede tener dos funciones: 1) Formar parte del sistema de transporte de señal, actuando como una referencia, en cuyo caso se conecta. 2) Apantallado, en ese caso acostumbra a no conectarse, o a hacerlo solo en un lado, si te funciona sin conectar déjalo así.
¿Cuando hablas de "conectar" te refieres a soldar? ¿Ó se puede conectar de otras maneras? ;)
Bueno, pues que conecteís muchas cosas bonitas en este 2010  :D :D Yo estoy empezando. ;D
El aficionado que quiere iniciarse en el diseño de altavoces acostumbra a utilizar el WinISD, lo malo es que hace años que el desarrollo de este programa está abandonado:
http://usuarios.lycos.es/zeroc/WinISD.zip
http://www.linearteam.dk/default.aspx?download=winisd
Existe alguno bastante mejor como el de esta página: http://www.boxsim.de/
http://www.boxsim.de/download/Boxsim111b.zip
http://www.visaton.de/bilder/forum/forum06/chassis-datenbank-alt.zip
El `pero´ en este caso es que está en Alemán, lo que hace un poco más difícil su uso, hay que esforzarse un poco más.
En esta página hay un tutorial:
http://hifi-selbstbau.de/index.php?option=com_content&task=view&id=62&Itemid=66
Y esta es la traducción `made in Google´:
http://translate.google.es/translate?js=y&prev=_t&hl=es&ie=UTF-8&layout=1&eotf=1&u=http%3A%2F%2Fhifi-selbstbau.de%2Findex.php%3Foption%3Dcom_content%26task%3Dview%26id%3D62%26Itemid%3D66&sl=de&tl=es
Los sajones continúan dando ciento y raya en poner a disposición de todo el mundo los conocimientos:
http://www.youtube.com/watch?v=4-7PMvGZsFo   Tutorial CMoy
http://www.youtube.com/view_play_list?p=759C80D65CFC80B7    Otros tutoriales
http://revision3.com/
y en esta página hay una documentación excelente sobre diseño de amplificadores y realimentación, no exactamente para principiantes pero merece la pena descargar los pdf y tenerlos guardados para el futuro:
http://linearaudio.nl/library-1.htm
Ya se han puesto esquemas de generadores anteriormente, pero un kit como este a este precio nos ahorra todo el trabajo de pasar un esquema a la práctica. Aunque la página es inglesa la pongo solo como referencia, supongo que se consigue en España:
Las frecuencias son fijas, pero lo curioso es que incluye funciones como Ruído Rosa:
http://www.esr.co.uk/velleman/k8065.htm
http://www.vellemanprojects.com/downloads/0/illustrated/illustrated_assembly_manual_k8065.pdf
En España:   http://www.cespedes.es/spa/item/1380457.html
...Y para hacernos nuestro MP3 estacionario:
http://www.esr.co.uk/velleman/k8095.htm
http://www.velleman.eu/downloads/0/infosheets/k8095_uk.pdf
Eduardo
Raúl, con toda esta información difícilmente puedo decir que no tengo idea de soldar un día de estos conecto el Weller y me dedico a quemarme la mano, así me pones muy difícil decir no al soldador. Gracias por la información.
Citarun día de estos conecto el Weller y me dedico a quemarme la mano
¡Se coge por el lado del plástico!  ;D ;D ;D
Otro programa gratuito para diseño de esquemas y circuitos impresos, e incluso simulación Spice, con la particularidad que lo hay para PC o Mac:
http://www.mccad.com/TotallyFreeMenu.html
B2 Spice no es, en absoluto, uno de mis simuladores preferidos, me parece muy poco intuitivo. Pero en esta página hay una serie de tutoriales muy interesantes acerca de temas como previos de phono y amplificadores de auriculares, simplemente se pueden trasladar a algún otro simulador más cómodo como SIMetrix o Tina TI:
http://www.beigebag.com/resources.htm
Especialmente interesante resulta el circuito de este amplificador de auriculares, en el que la realimentación se toma despues del condensador de salida, siendo en esto igual a un amplificador de válvulas, en el que se toma la realimentación en el secundario del transformador de salida, estándo en los dos casos realimentada únicamente la señal, sin incluir ninguna componente contínua:
Y en algún otro hilo se ha hablado del uso de buffers despues de los reproductores de CD para mejorar su sonido, este es un buen artículo sobre este tema:
http://www.tubecad.com/articles_2002/Power_Buffers/Power_Buffers.pdf
