USB / USB-->SPDIF, SISTEMA AUDIO CON MAC MINI
Iniciado por Accuracy, Marzo 02, 2014, 21:19:20
A mi el amplificador del Benchmark 1 y del 2, que me parece que dan resultado casi similar, no me gustan nada. Para eso prefiero mejor el Audiolab M-Dac, aunque de segunda mano no se encuentra tan fácilmente.
maty
#16
Vaya, ya están distribuyendo el DAC más famoso del año pasado:
theabsolutesound.com LH LABS "GEEK OUT" SHIPS TO ANXIOUS KICKSTARTER BACKERS
CitarGeek Out" is up to 25 times more powerful than a computer headphone jack, and will play super high resolution audio, up to 384kHz / 32 bit, decodes DSD and DSD2 (DSD64/128) audio natively and has two 3.5mm output headphone jacks.
It comes in three different power output models; Geek Out 450 ($199), Geek Out 720 ($249), and Geek Out 1000 ($299), and is available in four different colors, Diamond Black, Chalice Silver, Cobalt Blue, and Vivid Red...
=> http://www.lhlabs.com/stop
=> https://www.kickstarter.com/projects/gavn8r/geek-a-new-usb-awesomifier-for-headphones
CitarThree Geek types: 1 - Geek, 2 - Super Geek, 3 - Super-Duper Geek
Two outputs on all types (2 x 3.5 mm jack): line and headphones, both are variable in digital domain (64bit precision)
Volume control: two buttons and software (Operation System main volume slider sends volume data to Geek which implements the volume change in its internal volume control)
Line-out output impedance: 47 Ohm (on all types)
Headphone output impedance: 0.47 Ohm (on all types)
Max output voltage (line-out and headphone): 2.65 Vrms (Geek), 3,4 Vrms (Super Geek), 4 Vrms (Super-Duper Geek)
Max output power (headphone, 16 Ohm): 450 mW (Geek), 720 mW (Super Geek), 1000 mW (Super-Duper Geek)
Native decoded  music format in PCM: 44.1, 48, 88.2, 96, 176,4, 192, 352.8, 384 kHz / 16, 24, 32 bits.
Native decoded digital format in DSD: 2.822, 3.072, 5.644, 6.144 mHz / 1 bit
"Class A" analogue output stage, THD+N better than 0.005 %, SNR is 103dB (none-weighted), 109dB (A-weighted)
Sample rate indicator LEDs, machined aluminum enclosure in three different colors, with 6" USB cable, driver for PC (plug and play on MAC and Linux)
Pues eso, pronto sabremos cómo es acogido. Por cierto, la alimentación es vía USB... A ver si han incorporado un megafiltro para el ruido dichoso.
Benchmark
Digo yo que una cosa es el DAC y otra el amplificador de auriculares. ¿Lo probaste con cajas?
Cita de: maty en Marzo 03, 2014, 21:57:48
Si no se va a adquirir un amplificador de auriculares con un M-Dac se está muy bien, mueve incluso los LCD2 fácilmente y con gracia...además de otros... por eso también recomendé el NFB28.
El Benchmark 1 y 2 me gustan mucho pero no precisamente por su amplificador de auriculares el cual directamente no soporto... Aunque hay gente que si.
Accuracy
Aclaro que no lo voy a usar con auriculares, salvo en raras ocasiones. Sonará con mi amplificador y altavoces.
Con altavoces lo tuve con los monitores Krk Vxt de 6" y 4" y muy bien... pocas opciones habrá mejores al precio de segunda mano del aparato para ello.
Accuracy
Accuracy
#21
Y....cuáles son los rivales modestos de estos otros,
Accuracy
Voy a ello sin falta!
Maty, eres una máquina de facilitar información interesante.
Accuracy
Me da que voy a fundir 600 u 800€ en un MAC MINI... Ay madre!!!
Y eso solo es el comienzo...
maty
#25
¿Algún motivo en especial para que sea Mac?
Si no es así, te aconsejo un HTPC. Si quieres, con hard compatible con Mac y así tener un hackintosh. Y más económico y con mejor hard, digo.
Quien te puede aconsejar y vender estupendamente es el tendero. 100% confiable si no más.
-> http://changlonet.com/blog/
-> http://www.changlonet.com/tienda/pcs/htpc.html
en un mes te podré contar que tal el D100 de McIntosh, al menos comparándolo con el modesto (pero bastante competente) VDAC-II
Accuracy
Veeder:
Pues me interesa, yo voy a ir analizando en mi medida, otras opciones, además de las propuestas y ese Mcintosh.
Por cierto, Maty ¿Qué es y cómo eso de HTPC?
